Viewer does not apply ICC changes
Biscuit
Post by Biscuit »
Greetings
When you open an image in a viewer tab and change a color management setting in Preferences > General > ICC, the changes are not applied. You must close the tab and re-open it. This is a bug, as the desired behavior is for such changes to apply immediately.
Version 0.72 x64 (Dec 19 2014), Gentoo
Re: Viewer does not apply ICC changes
yes, you need to refresh the view
Biscuit
Post by Biscuit »
Yes, I'm asking for an improvement so it refreshes itself. This would make the program better.
Biscuit
Post by Biscuit »
This is still the case with 0.78. Luckily Ctrl+R uses the new profile when you reload.
