I've got pictures in 16:9 which i want to resize (smaller). I select my file, "convert", "transformation", "resize", fill "50%". But my file resized in 4:3.
I tried clicking "keep format" but it doesn't work.
PS : i use xnview in french.
PS : i used xniew in the past and didn't have this problem.
Thanks a lot.
Fred.
pictures resize in 4:3
Re: pictures resize in 4:3
You wish to reduce the image pixel dimensions by 50% while maintaining the ratio?
Could you post a screenshot of the settings you are using (XnView in French)?
Edit:
Do you have 'Garder les proportions' checked if that setting is present?
Edit:
papuche37
Thanks for your help.
Yes, i just want to reduce by 50% while maintaining the radio.
Yes i check "garder les proportions".
See my screenshots. PS : how to add 2 pictures in my post?
Please try these settings:
On the 'Général' tab, click on 'Ajouter...'
On the 'Transformations' tab, double-click on 'Image -- Redimennsioner'papuche37 wrote:Yes, i just want to reduce by 50% while maintaining the ratio.
papuche37
When i say "add 2 pictures" i want to say in this forum! lol !!!
And for your second screenshot, it's the same settings than me.
I don't understand where is the problem!
You did say 'in the forum'... Yes, lol !!!papuche37 wrote:When i say "add 2 pictures" i want to say in this forum! lol !!!
You can add further images the same way you added the first; you have placed the first image 'inline' in your post and can do the same with further attachments. You may possibly find the following link useful:
http://forum.xnview.com/viewtopic.php?f ... =0#p120077
I think I've found the problem, setting '50%' didn't work the way I expected, either, from other similar setup windows. Please try this procedure:And for your second screenshot, it's the same settings than me.
Click on the '%' radio button, then click on the button marked in red to the right, select 50%, and then -- with 'Garder les proportions' selected -- 50% should appear automatically in both the 'Largeur' and 'Hauteur' boxes as shown...
Edit:
Alternatively, you can key '50' into both the 'Largeur' and 'Hauteur' '%' boxes directly, without using the button outlined in red...
In some setup windows [possibly only in XNViewMP and XnConvert ??] when 'Garder les proportions' is selected, a value typed in one box is automatically also entered in the other.
papuche37
It doesn't work. Even if i click on the double arrow and select 50%, and check "garder les proportions", my picture is resized in 4:3.
And when i click on the arrows, all format displayed are in 4:3, none in 16:9.
I use the 2.32 release, with win 8.
In the past, i didn't have this problem (with XP).
