I am on a dir with about 10.000 jpg each about 1mb
pc is i7 with 4 cores + ht on 20gg
hdd is sdd so basically 200mb transfer speed 0ms
I selected 800x800 thumbnails and speed was about 8 pics/s wich is very poor
os is win 8.1
any chance to improve or is 8 files/s somewhat a hardlimit?
Poor performance while cataloging
immo2014
Re: Poor performance while cataloging
HI I switched to jpg thumb for database and decreased the size of thumb a little so speed is ok now. Kinda Problem is solved although U guess it could be possible to use multicore to parse the files faste
zip for catalog database was very slow (multicore?)
after all very decent sofware and only crashing a few times despite my insane testload of dirs with 10k pics
gj with xnview
gj with xnview
m.Th.
Read this: http://www.xnview.com/wiki/index.php/Xn ... e_solution
Tl;dr: Use WebP as compression. Put your DB on a 2nd drive if you can.
m. Th.
