hello!
I just stumbled upon this converter tool via google.
My goal is to convert my directory structure of 1000+ Canon RAW files to JPG.
I would like to lighten up the shadows a little and take back some highlights for each photo to take advantage of the extra RAW picture details before JPG compression.
But after some testing I am realizing now that XnConvert does not use the full RAW file but only the embedded jpg for conversion.
Did I do something wrong? Is there a Pro Version I can purchase?
Thank you very much for your time!
XnConvert RAW quality
- Forum Librarian
Re: XnConvert RAW quality
Welcome to the forum, Dater (-:
- Settings » Load format settings... » Camera RAW » Use [ Full size ]
DaterTheAndroid
Haha! I can't believe I missed that!
Thank you very much!
