Win 7 x64 - 0.72 - XMP Ratings not exported
firehorse
Post by firehorse »
I'm using XnViewMP 0.72 under Windows 7 x64.
I start with 2 pictures, Lighthouse.jpg and Lighthouse.tif. In Windows Explorer, I set them to 3 stars and 2 stars respectively.
In XnViewMP, they come up as 3 stars and 2 stars, as expected.
In XnViewMP, I set them to 5 stars and 4 stars respectively.
However, this is not reflected back into Windows Explorer.
There was a similar issue here http://newsgroup.xnview.com/viewtopic.php?f=62&t=30331 so in Settings I've made sure that Metadata / Ratings & Label / Export rating in XMP metadata is checked.
Is this a bug or am I doing something wrong?
Re: Win 7 x64 - 0.72 - XMP Ratings not exported
i have not this problem with 0.75, could you check?
firehorse
Post by firehorse »
I've updated to 0.75.
It works perfectly for jpg files but not for tif files.
Is this by design or ... :)
firehorse wrote: Is this by design or ... :)
a bug :)
PeterH
Post by PeterH »
In version 0.81 works ok for JPG but does not work for Sony ARW Raw files. Is it possible to fix this?
PeterH wrote:In version 0.81 works ok for JPG but does not work for Sony ARW Raw files. Is it possible to fix this?
XnViewMP can't change XMP from RAW files
