Menu item spacing on high-res display
photoken
Post by photoken »
Win7 Pro x64 SP1
XnViewMP 0.72 x64
Screen Resolution: 2880 x 1620, using Large Fonts setting (150%)
The icons for the menu items are overrunning the menu item text:
Ken
Yes, I think it can be eeeeeasily done...
Just take everything out on Highway 61.
Re: Menu item spacing on high-res display
Do you have same problem with 0.75?
photoken
Post by photoken »
Yes, the same problem exists with XnViewMP 0.75 (Sept. 21 version).
Ken
photoken wrote:Yes, the same problem exists with XnViewMP 0.75 (Sept. 21 version).
ok, a problem in the dark theme, please use fusion theme now...
photoken
Post by photoken »
XnViewMP 0.72 x64
It's a strange problem with the dark theme: If I switch to the "Cleanlooks" theme, the "Dark Theme" colours remain the same, but the icon spacing, etc., is corrected.
However, after closing and re-opening the program, the theme is now the "Cleanlooks"; and switching the theme to "Dark" and closing and re-opening the program shows the same problem with the icons in the "Dark Theme".
Ken
