Disable automatic change of landscape view
Putenschnitzel
Post by Putenschnitzel »
When looking at my pictures in the thumbnails there is a few ones with landscape view because I hold the camera like this when I made the picture. When double clicking on the thumbnail xnview automatically changes the view and rotates the picture to the normal view. How can I avoid this?
loth
Post by loth »
in XnView, press F12 or go to the options.
seek for something called "Rotate images based on EXIF orientation"
while seeking have a look at all the other wonderful options/features which make your life easier.
loth
loth wrote:in XnView, press F12 or go to the options.
Thank you, Loth, for your good and correct explanation. :-)
All I can add is a link to some background info on this issue in the FAQ "How to rotate images automatically?".
