10 bit display
NatanHaim
10 bit display
Post by NatanHaim »
Hello!
First of all, thanks for all your hard work on this project. XnView is really great!
I have started to bring-up a 10 bit testing environment. I am using nVidia Quadro k620 GPU with Eizo CG318-4K display using DisplayPort. I have confirmed using an OpenGL test based on the NVAPI article (https://www.nvidia.com/docs/IO/40049/TB ... 02_new.pdf) that it is working properly using a 10-bit grayscale ramp.
Now to my question... does XnView support display of 10 bit files? If so, which format should I use? I am familiar with DPX, PPM, TIF, but can convert to some other format if supported.
The files I am interested in are in the RGB color space with 4:4:4 sampling.
Appreciate any response!
EDIT:
If anyone has any suggestions for other programs which support native 10bpc display, please let me know! It would be really nice if I didn't have to program something in OpenGL for this :)
Best,
Natan Jacobson
Re: 10 bit display
no, 10-12-16bits images will be converted in 8bits
maa2
Re: 10 bit display
Post by maa2 »
10 years later... Does XnView support 10-bit color?
(most monitors and videocards support 10-bit color these days)
