0.76: Doesn't select area in image
kvoz123
Post by kvoz123 »
My system is openSuSE Leap 42.1/64. Install seems OK, but area selection doesn't work -- I could see the message
### resetViewport (310dee0) ==> 1272 594 (949 632) 0 38
MyBitmapView :: mousePressEvent
and ... nothing happens (area selection doesn't work and "crop" tool doesn't active).
I could start the old XnView 1.7 on my system, but it also shows the problem -- both program controls and image areas are semi-transparent with the rest of screen.
Re: 0.76: Doesn't select area in image
please check Settings>Interface>Mouse
kvoz123
Post by kvoz123 »
Thanks a lot, it works!
(On my wife' computer everything has been OK from the beginning ...)
