Solved // RAW (*.ORF) is shown in overview, JPG isn't
cooltour
Post by cooltour »
I might have something mis-optioned, from today on I get in the overview in a mixed-up folder of RAW and JPG (even when there are only JPG) the preview thumbnails of all RAW but the JPG images are only shown as a symbol.
And if the filter should only show pictures only the RAW are shown...
Where is the swich tu turn this behavior into "normal"?
Oliver
Re: RAW (*.ORF) is shown in overview, JPG isn't
Welcome to the forum, Oliver (-:
Which version of XnView and Windows are you running?
cooltour
Solved // Re: RAW (*.ORF) is shown in overview, JPG isn't
Post by cooltour »
It's XNview 2.34 on Win7/64.
And your links (well the "No jpg thumbnail in browser" indeed) helped me out of this dilemma.
I don't know who wrote it there but I deleted the JPG entry and get full view again.
Thx
