XnViewMP 0.78 Windows x64 (Jan 12 2016)
[Something to prepare]
1bit Binary image file
[Steps to reproduce]
1
[Tools] is chosen.
2
[batch conbart] is chosen.
3
A tab of [input:] is pushed.
3-1
A prepared picture, in window, drag and drop
4
A tab of [output] is pushed.
4-1
The item of the format
[Webp] is chosen.
4-2
[lossless] is chosen by the item of setting.
OK is pushed.
5
The one from the window lower right
[Convert] a button is pressed.
Experiment and result (picture referring)
1bit Binary image was changed to the various forms.
An error has occurred to a picture of 1bit.
Because jpg and jxr are a picture of 8bit.
A change succeeded as a result.
This is possible in nomal-xnview, so I wish to be improved.
Last
2 pictures used for a test are left.
When I read in high-zoom in XnViewMP, a picture is disordered.
Thank you for reading to here.
0.78: Batch convert: webp fails using 1bit binary image
abobong
Re: Using 1bit binary image, webp-Batch convert. failed.
you need to add a change color depth 24bits action
abobong
xnview wrote:you need to add a change color depth 24bits action
I have checked the reply content.
It was very helpful.
I posted a new article of related content.
http://newsgroup.xnview.com/viewtopic.p ... 85#p141385
