GUI bug in XnView 1.80.1
lopoz
Post by lopoz »
Fresh install of Windows & XnView (using XP style menu's)
This is what the problem is:
Using:
-Windows XP SP2
-ATi Radeon Mobility 9700
-Omega Radeon Drivers (Catalyst 5.7)
I'm only experiencing this on this notebook. I've installed it on a different notebook and it looks fine (with integrated Intel graphics)
Any ideas?
Re: GUI bug in XnView 1.80.1
Anonymous wrote:Fresh install of Windows & XnView (using XP style menu's)
Using:
-Windows XP SP2
Any ideas?
Strange, you have a display problem only with check box?
lopoz
Post by lopoz »
yes, only the checkboxes are weird like this..
Also, if I pass over them they change to formes similar to the ones in the screenshot.
I'll see if I can make some more screens, so you can see what I mean
[edit]
To make matters even stranger:
When I open a next 'level' in the menu, the checkboxes in the previous level seem to correct themselves..
So if I open the 'edit' menu, the checkboxes are weird. If I then open the 'View As' menu, the checkboxes in the 'Edit' level are corrected, but the ones in the 'View As' menu are weird..
ckv
Post by ckv »
If you would have been using windows 98 my quess would been resource memory overflow, but Windows XP haves virtually unlimited resource memory. It sure looks like it though.
lopoz
Post by lopoz »
I don't know..
These are my specs:
Sony Vaio VGN-A117S
Intel Pentium Centrino 1.7 GHz (Dothan Core)
Intel 855PM board
ATi Mobility Radeon 9700
1 Gig RAM
80 Gig HD
Anything important missing?
Any settings you want to know or that I can change to see if it makes a difference?
lopoz
Post by lopoz »
I've found out what the problem is!
When I disable the Transition effect for menus and tooltips, the problem occurs!
Also, setting it to 'Fade effect' instead of 'Scroll effect' also introduces the weird checkboxes
lopoz wrote:yes, only the checkboxes are weird like this..
You don't use win98 so this not the problem of ressource
lopoz
Post by lopoz »
Do you think it could be a driver problem, seen as the Windows Display Settings are causing the problem?
