When we draw a box over part of an image and push delete, MP will clear the area to a set colour.
I see I can change the colour in View mode under Edit > Background colour
And can I change it to transparent? I want to erase to transparent.
How to set colour when delete selected area
Brother Gabriel-Marie
- Forum Librarian
Re: How to set colour when delete selected area
<!--// DELETED //-->
But there's no "transparent" to be chosen from in that dialogue.
- Forum Librarian
- Forum Librarian
Does this do the trick, Br. Gabriel-Marie?XnTriq wrote:Image » Change color depth... » 32 bits / Alpha [ 255 ]
The Delete key (= Edit » Clear) should make the selected portion of a 32-bit image fully transparent, revealing the checkerboard background in that area, if the corresponding option in Tools » Settings... » View » View is activated.
Ah, okay, I got that.
So, it will erase to the background colour.
If the image has transparency it will erase to transparent.
But if it doesn't (like for a jpeg) it will erase to background colour set in Edit > Background Color.
Okay. That sort of makes sense.
If it is a png, I am also able to change the background to transparent (if it isn't) by using Edit > Change Color Depth > 32bit. Good!
Thanks for your attention, XnTriq.
- Forum Librarian
Yes, exactly. (Sorry for the confusion caused by my previous replies.)Brother Gabriel-Marie wrote:So, it will erase to the background colour.
