Dear all,
there is no Problem using XnView to see MP4 Video's with H.264 Codec. Just if they have a bigger resolution than 1920x1080 XnView crashes. Also in the preview screen.
Here the screenshots:
Do you have any idea?
Regards
Dino
MP4 H264 bigger 1920x1080 crashes Xnview
dino
dino
Re: MP4 H264 bigger 1920x1080 crashes Xnview
Dear all,
I just tested the same with XnView Classic. It's the same Problem.
Regards Dino.
Regards Dino.
codec problem??
dino
Dear Pierre,
yes you are right this is the Problem. I investigated in the issue and found that the "Microsoft DTV-DVD Video Decoder" is used in my system per default. And it supports only a maximum Resolution of 1920 × 1088 pixels. But would it in this case not be possible Xnview don't show the preview and don't crash?
https://msdn.microsoft.com/en-us/librar ... 85%29.aspx
Regards,
Dino
Regards,
Dino
dino
Dear Pierre,
it's working fine now. I just hat to disable the "Microsoft DTV-DVD Video Decoder" via this tool: http://www.nirsoft.net/utils/installed_codec.html
Regards
Dino
Regards
Dino
