Move images to hidden folders
bronYaur
In the browser, I cannot use the move command to move images to a hidden folder. I have un-hidden the folder, but, the folder does not exist when I attempt to move an image.
Re: Move images to hidden folders
You mean in the "Copy/Move to" dialog box?bronYaur wrote:In the browser, I cannot use the move command to move images to a hidden folder. I have un-hidden the folder, but, the folder does not exist when I attempt to move an image.
bronYaur
Type the dir-name---
- Right, the hidden folder doesn't appear in the tree of the box; BUT if you type the name of this hidden folder in the lower field as the target path that works, the file is moved alright, I just checked that here under Win 98 SE - XnView 1.80.2
ouistiti
IMHO, this lack of hidden folders in the tree is an annoying lacuna. They might be displayed like in <Windows>, with the appropriate icon :
I guess it's available in the <Shell32.dll> of Windows…
Paul
Paul
1,77245385090552... •
Lesmo16
bronYaur
