XnView can add addons from menu Filter as standalone buttons to toolbar. That's great.
I'd like to have an option to add "Open with <Program name>" from menu File->Open with as a toolbar button too.
I have read this post http://newsgroup.xnview.com/viewtopic.p ... ar#p129406 , but can't figure if it is possible to set call to executable as command for button. From what I tried it doesn't work, and there's no predefined commands like cmd_OpenWith_0.
{RESOLVED} "Open with <External application>" to toolbar
Mixer
- Banned
captaincavern
Re: Ability to add "Open with <External application>" to too
Setting an external program as toolbar button works fine. You create a new button by using the append button and then you browse for an executable and an icon.
Mixer
- Banned
Ah-hah, so that's how it works. When I tried to add button for executable for the first time I skipped setting icon, because buttons for starting addons work even without icon. External app even starts with currently displayed image. Thanks for the tip!
- Forum Librarian
Re: {RESOLVED} "Open with <External application>" to toolbar
Related topics:
- Toolbar presets
- Toolbar buttons for “cmd_Cut” & “cmd_Copy”
- Add button to Toolbar
- Exportable XNView CFG / INI File?
- Backup and restore
- Full Screen mode icons
- how to open a file with photoshop
- Toolbar Button Parameters
- How to "Batch" several commands via Icon in the Viewer?
[color=green]C:\Program Files\XnView\foo.bar[/color] wrote:Code: Select all
[Default Toolbar] count=1 button1=C:\Program Files\PDF-XChange\PDFXCview.exe,0 cmd1=C:\Program Files\PDF-XChange\PDFXCview.exe [View Toolbar] count=1 button1=C:\Program Files\PDF-XChange\PDFXCview.exe,0 cmd1=C:\Program Files\PDF-XChange\PDFXCview.exe [Browser Toolbar] count=1 button1=C:\Program Files\PDF-XChange\PDFXCview.exe,0 cmd1=C:\Program Files\PDF-XChange\PDFXCview.exe
