Question to "Edit IPTC-IIM/XMP" window
herb
Post by herb »
I work with XnViewMP 0.79 and I have a question to "Edit IPTC-IIM/XMP" window:
In this window I see 4 buttons; 3 of them are clear to me
- Button "Save template ..." which stores the actual values in a file <template-name>.iptc
- Maybe a dialog is missing which asks for overwrite yes/no in case the name of an existing file is entered.
- Button "Load template" which reads a previous stored template.
- Button "Clear all fields" which does the clearing.
Totally unclear to me is button "Load template V1 ..." which asks to open a file with extension .ipt
Can someone explain to me which workflow will be started with this button?
Thanks in advance and
Best regards
Herb
Re: Question to "Edit IPTC-IIM/XMP" window
it's the iptc template saved by XnView Classic
herb
Post by herb »
Hello Pierre,
thanks for the explanation.
But I have another question: Can someone upload such a file in order to come to know its syntax/content?
Thanks in advance
Best regards
Herb
it's a binary file
