Hello.
I want to move files with drag&drop, but when I drag some pictures or folders onto others folders, Xnview begins copying these files. How can I fix or set up it?
Drag&drop copies files instead of moving them
Re: Bug with drag&drop
with XnView Classic?
When dragging and dropping files to a folder on the same drive (e.g. from C:\Test1 to C:\Test2), XnView will move the files. When dragging and dropping files to a folder on a different drive (e.g. from C:\Test to D:\Test), XnView will copy the files. FAIK, Windows Explorer behaves exactly the same way.kehlerr wrote:Hello.
If you want to change this, please press 'Strg' for forcing the copying or 'Shift' for forcing the moving of the files.
