Cleaning Metadata Without Altering Image
nbrtyyujm
I clicked Remove All Metadata, but when I Save the file, it is much larger in size so XnView must be reproccessing the image. How can I strip the metadata without altering the image?
Re: Cleaning Metadata Without Altering Image
in browser, use clean metadata. 'Save' recompress the imagenbrtyyujm wrote:I clicked Remove All Metadata, but when I Save the file, it is much larger in size so XnView must be reproccessing the image. How can I strip the metadata without altering the image?
nbrtyyujm
Using Clean Metadata from the browser doesn't recompress the image? In a hex editor the cleaned file looks different from the original. I was expecting only the beginning of the file where the metadata is to be different.
- Forum Librarian
Did you activate Optimize (Huffman table)?nbrtyyujm wrote:Using Clean Metadata from the browser doesn't recompress the image? In a hex editor the cleaned file looks different from the original. I was expecting only the beginning of the file where the metadata is to be different.
Calvin Hass ([url=http://www.impulseadventure.com/photo/optimized-jpeg.html]What is an Optimized JPEG?[/url] » Does JPEG Optimization affect Image Quality?) wrote:No! The huffman table optimization is a lossless (reversible) process that has absolutely no effect on the resulting image quality. If one has the option, it is almost always best to enable JPEG optimization. The extra file size savings can't hurt. However, as it may potentially reduce compatibility with some bad JPEG decoders, this may be enough of a reason for you to disable it.
nbrtyyujm
The only item activated is EXIF. Everything else is unselected.
- Forum Librarian
Bug confirmed
I used FujiFilm FinePixS1Pro (1).jpg and CompareIt! (Find moved sections & Align mode activated) for my tests.
when you use 'Clean metadata' in browser mode?XnTriq wrote:Bug confirmed![]()
- Forum Librarian
Yes, in the browser. (cmd_CleanMetadata isn't available in view mode, I believe.)xnview wrote:when you use 'Clean metadata' in browser mode?
