.max files' thumbnails not displaying in XnView MP
kevin.internet
Post by kevin.internet »
In XnView classic, .max files do display the thumbnail correctly for me.
In XnView MP, the .max files are not displaying the thumbnails.
I tried Tools-Settings-General checked Show all graphic formats - restarted XnView MP - no change
Am I missing a setting somewhere in the interface to be able to display the .max files' thumbnails ?
Re: .max files' thumbnails not displaying in XnView MP
could you send me a .max file?
kevin.internet
Yes, ..
I have sent you a .max file.
these files use plugin Xcompound.dll, if you use the 32bits version of XnViewMP, you can use it
kevin.internet
I removed the 64 bit version and installed the 32 bit version.
The thumbnails for max files still do not display. It just shows the 3dsmax icon.
Do I need to associate to this .dll somehow?
kevin.internet wrote:I removed the 64 bit version and installed the 32 bit version.
I think you need to download the plug-in from this link, it's the 'Compound' plug-in for 3DSMax, and then extract it and put it in the XnView MP x32 plugins folder.
I assume you are using Windows.
Having located it I've attached a copy anyway...
