XnView MP cannot start up after image deleted/corrupted
DeusExMamiya
Post by DeusExMamiya »
I'm using the latest Mac version of XnviewMP (I reinstalled it from the website right now just to be sure, and it made no difference).
What seems to be a new feature of XnviewMP is actually a curse :evil: : I am referring to the way in which it reloads whatever images were open at the time it was last quit.
This "feature" has completely disabled my XnViewMP installation :bug: , because it is trying to reopen a deleted or corrupted image - and fails of course - so it gets completely stuck: there is no getting past the error popup which says " ! File can't be loaded!" [the only option to respond is "OK", which just closes the app again, and you're back to square one].
At the very least, this needs better error handling.
Better still, just stop reloading old images again. If we want them again, we'll get them again :) . Even if there were no problems with deleted images, it slows down the startup process.
Regards,
Ray
Re: Bug: XnviewMP cannot start up after image deleted/corrup
Ok, a bug...
you need to disabled session saving
Kiwi_John
Post by Kiwi_John »
Hi Pierre. I have the same issue - how do we disable session saving?
I can't start xnviewmp even after deleting and re-installing...
are you able to edit the xnview.ini?
Kiwi_John
Post by Kiwi_John »
Hi Pierre, can't find a file called xnview.ini on my mac anywhere (nor any other editable xnview.* file....).
Thanks
on mac, you have it in ~/.xnviewmp folder
Kiwi_John
Post by Kiwi_John »
Thanks Pierre. I found the ini file and changed sessionsave to false but still getting the "File can't be loaded!" error when I try to start Xnviewmp. That happens both when I click on a file to open and also when I just try to start Xnviewmp from the Applications.
Welcome aboard, Kiwi_John (-:
  1. Close XnViewMP.
  2. Delete the following lines from the [Start] section of your INI file:
    • session=
    • sessionIdx=
    • sessionSave=
  3. Start XnViewMP.
  4. Go to Tools » Settings... » General » General:
    • Deactivate Confirm 'Session' saving on program exit.
    • Click the Reset all confirm prompts button.
  5. Confirm the changed settings with OK.
Kiwi_John
Post by Kiwi_John »
Thanks! That did the trick - much appreciated.
