0.82: mp4 playback problems
Fritzle
After installing version 0.82, I encounter problems playing some mp4 video files. While I can hear sound, preview and/or main window stays black. Moving progress slider manually a little bit to the right makes the video play normally until the end. But pressing the play/pause button instead makes executable hang. Problem does not occur with version 0.81. Problem disappears when copying version 0.81's executable xnviewmp.exe into version 0.82's installation directory. Affected video files play successfully with Windows Media Player, VLC Player, etc.
Re: 0.82: mp4 playback problems
See Issue 967 for details.
This problem is supposed to be fixed in XnView MP 0.82 or later. Could you please try and confirm the bug fix, Fritzle?
Dreamer
XnView: MP 0.85 beta 1 - 64 bit
OS: Windows 10 - 64bit
No video/sound with any mp4 file in browser/fullscreen/viewer mode.
Dreamer
could you try with useQtav=false?Dreamer wrote:XnView: MP 0.85 beta 1 - 64 bit
@Pierre: What does this setting do? What happened to the old "VideoMode" setting? Could we please rename this setting to something meaningful (e.g. useQtAVVideoPlayer)?xnview wrote:could you try with useQtav=false?Dreamer wrote:XnView: MP 0.85 beta 1 - 64 bit
videomode is ignored now. Ok i'll use useQtAVVideoPlayerhelmut wrote:@Pierre: What does this setting do? What happened to the old "VideoMode" setting? Could we please rename this setting to something meaningful (e.g. useQtAVVideoPlayer)?
Good, thank you!xnview wrote:videomode is ignored now. Ok i'll use useQtAVVideoPlayerhelmut wrote:@Pierre: What does this setting do? What happened to the old "VideoMode" setting? Could we please rename this setting to something meaningful (e.g. useQtAVVideoPlayer)?
Dreamer
Beta 2, useQtav=false, example.mp4 and other mp4 files don't work.
0.84, useQtav=false, example.mp4 and other mp4 files work good.
Pierre, should I change any ini option in beta 2? I'm using the ini from beta 1 without any changes.
Dreamer
Dreamer
Beta 2, useQtav=true, example.mp4 and other mp4 files work good.
Dreamer
When thinking about it, again, I'd suggest "useInternalVideoPlayer". This would be both clear and not too technical.xnview wrote:videomode is ignored now. Ok i'll use useQtAVVideoPlayerhelmut wrote:@Pierre: What does this setting do? What happened to the old "VideoMode" setting? Could we please rename this setting to something meaningful (e.g. useQtAVVideoPlayer)?
ok, for useInternalVideoPlayerhelmut wrote:When thinking about it, again, I'd suggest "useInternalVideoPlayer". This would be both clear and not too technical.xnview wrote:videomode is ignored now. Ok i'll use useQtAVVideoPlayerhelmut wrote:@Pierre: What does this setting do? What happened to the old "VideoMode" setting? Could we please rename this setting to something meaningful (e.g. useQtAVVideoPlayer)?
3,2,1.. Decided!xnview wrote:ok, for useInternalVideoPlayer
I've just downloaded the sample file provided by Fritzle and tried in XnView MP 0.85 beta 4:
There's just a black screen (preview or viewer) and no video and no sound in browser/fullscreen/viewer mode. Looks like the internal player cannot handle MP4 files.
Reproduced
Dreamer
With useInternalVideoPlayer=true the example.mp4 file and the other mp4 files (1080p) work good here, browser preview/fullscreen/view modes, MP 0.85 beta 4, Windows 10 64 bit.
The example.mp4 video is very short, please try the other mp4 files.
Dreamer
