2.38: Libraries mix cause warnings in PlugIns dialog
yoba
Post by yoba »
<Moderator's note: This topic has been split from another topic>
Versions are available on the normal XnView Download page.
http://www.xnview.com/en/downloadwin32.html - there is no such page anymore.
Should be http://www.xnview.com/en/xnview/#downloads
Starting from version 2.37 in extended archive (XnView-win-full.zip) (don't know about others) in "Plugins" there are two x64 libs libpng16-16.dll and zlib1.dll which, I suppose, for bpgdec.exe last version (0.9.6) of which is x64 only; but in the same time why libjpeg-62.dll is x86 and from previous version? Complete mess! :shock: . It's, of course, don't work on x86 systems and also triggers annoying warnings in "Info" => "Plug-Ins Information..." dialog.
Possible solutions:
1 - Revert bpgdec.exe to previous x86 version (0.9.5), also don't forget to reverting libs - zlib1.dll and libpng16-16.dll to libpng15-15.dll x86 versions.
2 - Don't include bpgdec in full archive but made it separate download with warning about only x64 version.
3 - Change bpgdec to Xbpg.usr - BPG-Plugin which is much better imho
Sorry for terrible English :mrgreen:
Re: 2.38: Libraries mix cause warnings in PlugIns dialog
Thank you for registering and welcome to the XnView forum, yoba.
Thanks for this hint, I've just corrected the download link.
yoba wrote:Starting from version 2.37 in extended archive (XnView-win-full.zip) (don't know about others) in ..
Here someone else (Pierre) will answer.
yoba wrote:Sorry for terrible English :mrgreen:
Your English is not too bad, at least I think I understood what you mean. ;-)
yoba wrote: Starting from version 2.37 in extended archive (XnView-win-full.zip) (don't know about others) in "Plugins" there are two x64 libs libpng16-16.dll and zlib1.dll which, I suppose, for bpgdec.exe last version (0.9.6) of which is x64 only; but in the same time why libjpeg-62.dll is x86 and from previous version? Complete mess! :shock: . It's, of course, don't work on x86 systems and also triggers annoying warnings in "Info" => "Plug-Ins Information..." dialog.
Right i'll fix it
