0.84: Saving ignores JPEG quality
Hi, I think I found a bug in the new MP v0.84: If I try to save an image as jpeg the file size always stays the same (rather big) no matter what jpeg quality I choose. For me it looks as if the quality is always stuck at 100%. Can anyone confirm this issue?
Re: v0.84: Saving ignores JPEG quality
Due to an [unexplained] limitation in the Qt toolset used for 'MP, compression can only be set in File > Format settings... in the Viewer ...Guinness wrote:Hi, I think I found a bug in the new MP v0.84: If I try to save an image as jpeg the file size always stays the same (rather big) no matter what jpeg quality I choose. For me it looks as if the quality is always stuck at 100%. Can anyone confirm this issue?
Thanks for your reply. That was the way I tried to set the jpeg quality and this sadly has no effect on the quality and/or file size. Could you please check, if you are able to change the jpeg quality if you have installed v0.84?
Guinness wrote:Due to an [unexplained] limitation in the Qt toolset used for 'MP, compression can only be set in File > Format settings... in the Viewer ...
I'm on vacation and only have an Android tablet, could someone else check please?
But do you have 'use estimated original quality' [or something similar] checked, which might be the explanation??
I re-checked it and no, this option isn't selected.cday wrote:But do you have 'use estimated original quality' [or something similar] checked, which might be the explanation??
Re: 0.84: Saving ignores JPEG quality
I've tested Save as... as well as Export... but haven't been able to reprodruce the issue.
The status bar isn't updated when saving, see topic 0.84: file size not renewed after resizing the image for details.
Is this perhaps the problem you experience, Guinness?
No feedback and not reproducable.
Closed (Please post here if the problem still occurs.)
