0.84 Ubuntu: Cannot add icon to new (command) tool bar item
yoramdavid
Post by yoramdavid »
I am in Ubuntu Mate 16.04 and use XnViewMP Version 0.84 x64
I right click on the tool bar and choose "customize toolbar" I then add a new entry which is a command, in this case I want it to open the image with gimp.
The new button works fine, I can change the label but I cannot add an icon, when I browse for an icon, there is nothing visible on the browser window to choose from as if it did not recognize icons. Or any other image file I tried.
The only way to make it display a list of files in the browser window is through a search, but it will not load any image file found there.
Happens both on browser view and image view.
Greetings.
David.
m.Th.
Re: Cannot add icon to new (command) tool bar item
Post by m.Th. »
Hi David!
Welcome among us!
It works for me (see my specs in signature). Take care, it needs an .ico format (best) or icons embedded in .exe or .dll . It seems that accepts also PNG but I don't know the limitations (size, color depth etc.).
m. Th.
yoramdavid
OK, then it must be a problem with my system?
Incompatibility with Ubuntu Mate?
There is an image of what I mean: Any work around?
m.Th.
Post by m.Th. »
yoramdavid wrote:OK, then it must be a problem with my system?
Did you try an .ico file?
m. Th.
