I want to MOVE files from one folder into another folder, on the same drive.
But I have to hold down the Command key (MAC) or it will COPY by default.
I looked everywhere to find a box I could click to change this default action.
This is very annoying when moving many pictures.
I know there are other ways to do a MOVE but I want to drag and drop.
0.84 MacOS: Drag&Drop problem: Copy by default
larenm123
Re: MacOs: Move/Copy problem: Copy by default
Thank you for registering to the XnView forum and your request, larenm123.
Copying instead of moving is a bug on MacOS, see topic Drag and Drop Copy/Move. I just moved your request to "MP - Bug reports" that's the right place for it.
@Pierre: Could you please try to reproduce and confirm this bug on MacOS?
jscode
Re: 0.84: MacOS: Drag&Drop problem: Copy by default
I use XnViewMP 0.84 on macOS 10.11.5, and can confirm this behaviour.
O.k., thank you, I can also reproduce the problem. Issue 1040 is fixed in next version.
This problem is supposed to be fixed in XnView MP 0.85 beta 1. Please check and confirm the bug fix here.
