Clipboard incompatibility of MP and Classic
  1. Open logo.png in XnView MP and go to EditCopy to clipboardImage data.
  2. Start XnView Classic and go to EditImport Clipboard.
Re: Clipboard incompatibility of MP and Classic
XnView classic want to import a premultiplied bitmap :(
Thanks for clarifying, Pierre. Most users won't use both editions of XnView side-by-side anyway, let alone transfer image data through the clipboard from MP to Classic or vice versa.
XnTriq wrote:Thanks for clarifying, Pierre. Most users won't use both editions of XnView side-by-side anyway, let alone transfer image data through the clipboard from MP to Classic or vice versa.
Hmm, I think that differences in the behaviour of XnView Classic and XnView MP should be avoided if possible. If I understand right, it's XnView Classic which behaves wrong or unexpected. As long as there is a way to workaround, it's o.k..
helmut wrote:If I understand right, it's XnView Classic which behaves wrong or unexpected.
It's both ways (MP → Classic & Classic → MP).
Samples:
XnTriq, I'm still not clear: Is there a problem that should be fixed in XnView MP? Or in XnView Classic? Or both?
helmut wrote:XnTriq, I'm still not clear: Is there a problem that should be fixed in XnView MP? Or in XnView Classic? Or both?
Both, I believe. However, if I'm not misinterpreting Pierre's comment, …
xnview wrote:XnView classic want to import a premultiplied bitmap :(
… this is a limitation that can't be fixed.
O.k., I partly understand.
:arrow: Closed (There is no bug in XnView MP. And XnView Classic cannot be changed.)
