Tried to rename some files on the network. MP froze for a few min before I killed it. I'm left with some tmp files.
Are you doing something so it's making copies instead of just renaming?
0.84: Freeze when renaming files on network
Re: 0.84: Freeze when renaming files on network
I've just tried to reproduce the problem but it works fine:
- Manually renamed individual image files in a folder on a network drive
- Batch renamed 12 image files in a folder on the network drive
All that I found is that when starting batch rename there is no wait cursor and nothing. After some few seconds all files are displayed with their new name.
- Which OS (Windows, ...) and version do you use?
- How and where (Browser, Viewer) do you perform renaming? How many files do you rename?
m.Th.
...aaaaand what is the speed of your LAN datastream? (Network + storage)
Try to rename in the OS' file manager? It takes the same amount of time?
m. Th.
obelisk
Thank you for providing some additional info.
- Does the problem still occur with XnView MP 0.85?
New
