Issue with selection tool in 0.84
triiku
Post by triiku »
For some reason every time I try to make a selection when working with a raw image (CR2 in this case), the selection tool treats the top left quadrant of the image as the entire image, not allowing one to select anything else.
Re: Issue with selection tool in 0.84
Thank you for registering to the XnView forum and your request, triiku
triiku wrote:For some reason every time I try to make a selection when working with a raw image (CR2 in this case), the selection tool treats the top left quadrant of the image as the entire image, not allowing one to select anything else.
Sounds like a strange problem. Which OS (Windows, Linux, MacOS) do you use? In which mode (Viewer or Fullscreen) do you try to make the selection?
