0.84: How to wipe your entire catalog
m.Th.
Post by m.Th. »
Disclaimer: Do NOT try this on your production catalog - or make sure to have a WORKING backup ready!
Steps:
0. Have some folders cataloged. Have some images with Ratings, Color Labels and Categories
1. Go to Tools | Settings | Catalog
2. Click on Optimize...
3. Select the following options
4. Press Ok. The „optimization” process begins...
Expected: Have only the files which are reachable (directories which are still on disk/LAN etc.)
Actual: The catalog is deleted entirely (!!)
m. Th.
Re: 0,84: How to wipe your entire catalog
I've just tried with 0.84 and I cannot confirm: Existing files are still assigned to categories.
m.Th.
Post by m.Th. »
helmut wrote:I've just tried with 0.84 and I cannot confirm: Existing files are still assigned to categories.
Perhaps because the files are re-read from embedded metadata?
Re-test and look at Tools | Settings | Catalog - do you see in the Cached Directory list many directories?
m. Th.
m.Th.
Re: 0.84: How to wipe your entire catalog
Post by m.Th. »
Ok, found the problem - I will contact Pierre privately.
m. Th.
m.Th. wrote:Ok, found the problem - I will contact Pierre privately.
O.k..
@Pierre: Please post here once you could reproduce m.Th.'s problem.
O.k..
it was a new bug in the 0.85 beta
xnview wrote:
O.k..
O.k.. Please make sure that there's a phase of beta testing for all forum users.
m.Th.
Post by m.Th. »
xnview wrote: it was a new bug in the 0.85 beta
Fixed now. :)
m. Th.
