Renumbering files
Renumbering files
The following option was recently added to NConvert to enable files to be renumbered:
-n start end step : Begin End Step (for image sequence)
If I use the following code to renumber four input files 01L 01R 02L 02R :
Expected result: the files are renumbered to 001 002 003 004
Actual result:
Conversion of Input\01L.jpg into Output\001.jpg OK
Conversion of Input\01L.jpg into Output\002.jpg OK
Conversion of Input\01L.jpg into Output\003.jpg OK
Conversion of Input\01L.jpg into Output\004.jpg OK
Conversion of Input\01R.jpg into Output\001_1.jpg OK
Conversion of Input\01R.jpg into Output\002_1.jpg OK
Conversion of Input\01R.jpg into Output\003_1.jpg OK
Conversion of Input\01R.jpg into Output\004_1.jpg OK
Conversion of Input\02L.jpg into Output\001_2.jpg OK
Conversion of Input\02L.jpg into Output\002_2.jpg OK
Conversion of Input\02L.jpg into Output\003_2.jpg OK
Conversion of Input\02L.jpg into Output\004_2.jpg OK
Conversion of Input\02R.jpg into Output\001_3.jpg OK
Conversion of Input\02R.jpg into Output\002_3.jpg OK
Conversion of Input\02R.jpg into Output\003_3.jpg OK
Conversion of Input\02R.jpg into Output\004_3.jpg OK
Each input file is renumbered four times instead of once...
Am I misunderstanding the intended use of the option, or is this a bug?
Re: Renumbering files
-n was not recently added :)
you need to use
xnview wrote:-n was not recently added :)
You are right :D
But I'm confused because I clearly recall an existing option being modified within the last year or two to add, I think, a step parameter, but I can't find any reference to that now.
xnview wrote:you need to use
I tried that code and many variations, but couldn't get the expected renumbering... :(
I don't know if the renumbering option could possibly only work for a filelist input, for example??
BTW in testing older NConvert versions, I believe I saw different results in recent versions compared with earlier versions, but as none actually worked I didn't stop to record the actual outputs. I mention it in case the issue arises in the future in another thread.
I finally found the following using NConvert without the -n option works:
As my immediate need is to renumber files sequentially incremented by one using simple code, that one-line solution meets my needs very well! Thanks for giving us NConvert! :D
Related topics (for future reference):
[color=green]WhatsNew.txt[/color] wrote:XnView v2.37 (LIBFORMAT v6.92) 10/11/2016:
* NConvert: Multipage extract - http://newsgroup.xnview.com/viewtopic.php?f=57&t=33879
XnView v2.36 (LIBFORMAT v6.88) 04/29/2016:
* NConvert: -t start step for number in output name
XnView v2.34 (LIBFORMAT v6.80) 07/09/2015:
* NConvert # in filename - http://newsgroup.xnview.com/viewtopic.p ... 2&p=127142
