Filename installer with version number
Sirio
Post by Sirio »
Hello.
I just propose, if it's possible, that the file name of the XnViewMP installer get the version number inside.
Actually is always : XnViewMP-win-x64.exe
I propose this way: XnViewMP-win-x64_v0.86.exe
Is better to identify immediately which file we have in the computer and it avoid to overwrite a previous version while downloading the new version.
What do you think about?
Sirio
Re: Filename installer with version number
If it practical for Pierre, it would simplify installing new versions... [Normally ZIP for me] :D
m.Th.
Post by m.Th. »
+1
m. Th.
Sched
Post by Sched »
+1 ! Good idea!
Sirio
Post by Sirio »
OK, I can understand. I will follow to do it myself. :( :mrgreen:
Sirio
the problem is the download servers which have a link, and often don't update it
