Problems to migrate toolbar settings
sibojan
I have customized the xnview toolbar like this However, it always goes back to the default when the entire xnview folder was copied to another computer. I followed the thread Info about XnView's settings (store & load) at http://newsgroup.xnview.com/viewtopic.php?f=17&t=1547 but did not have success. I am sure the xnview.ini was copied togeahter.If helpful, I can send my foo.bar file for troubleshooting as well.
Re: Problems to migrate toolbar settings
yes please send me it
sibojan
Should I send it by email? If so, what is yours? my email is siboj9 α† gmail δ○† com.
Thank you for the prompt support.
Reason: E-mail address obfuscated
- Forum Librarian
sibojan
Sent by email.
Thank you.
Thank you.
