Hello!
I've got a problem with XnV 1.5/1.68 (both static and openmotif) under SuSE Linux 8.2. When I try to open the "Open..."-,
"View in hexa..."-, "Browse..."-, "* Convert..."- or "General Options..."-window or passed a filename in the command line it crashes with these messages:
Warning: Connot convert string "-*-helvetica-?-?-normal-*-?-?-?-?-*-*-?-?" to type FontStruct {already occurs when opening menu}
XLoadQueryFont error ******** {only when try to open "Browse..."}
X Error of failed request: BadName (named color or font does not exist)
Major opcode of failed request: 45 (X_OpenFont)
Serial number of failed request: ?
Current serial number in output stream: ?
? stands for different strings depending on what I've tried to open. So, only these windows are possible to have a look at:
"XnView v1.68" (main), "Capture setup", "Slide Show", "Available formats", "Thanks...", "Infos", "About XnView". All the
others only appear for a really short time. When a filename is passed, you can see the "Loading..."-window for short, but
that's the end. It isn't possible to see any pics without the logo in the "About XnView"-window!
Here is a short list of what I've installed, I can post a whole if anybody likes.
X: 4.3.0-15 (1024x786x24, framebuffer driver)
Kernel: 2.4.20-4GB-athlon (SuSE)
OpenMotif: 2.2.2-204
some font packages
Is anybody out there who can help me???[/i][/b]
XnV under SuSE 8.2
Re: XnV under SuSE 8.2
Could you check if you have helvetica font?stefan wrote:Warning: Connot convert string "-*-helvetica-?-?-normal-*-?-?-?-?-*-*-?-?" to type FontStruct {already occurs when opening menu}
stefan
