I try to print images fitting it on a sheet and i put directory and filename with extension, the image is printed ok but the letters are windwings font, i tried to change it in options, deleting the xnview.ini and searching [print] in the ini, and of course installing the latest version, and there is no chance to print in any other font.
Can anybody please help me?
My info file is is printed in windwings.
Re: My info file is is printed in windwings.
Currently not possible, but i'll add itDICEASE wrote:I try to print images fitting it on a sheet and i put directory and filename with extension, the image is printed ok but the letters are windwings font, i tried to change it in options, deleting the xnview.ini and searching [print] in the ini, and of course installing the latest version, and there is no chance to print in any other font.
@Pierre: Please reread the post.xnview wrote:Currently not possible, but i'll add itDICEASE wrote:I try to print images fitting it on a sheet and i put directory and filename with extension, the image is printed ok but the letters are windwings font, i tried to change it in options, deleting the xnview.ini and searching [print] in the ini, and of course installing the latest version, and there is no chance to print in any other font.
I have no clue why all the text in your prints are in Wingdings. I guess that XnView uses default font of Windows for printing. Or perhaps a specific font which is not available on your system. I think only Pierre knows.
Yes i use default fonthelmut wrote: I have no clue why all the text in your prints are in Wingdings. I guess that XnView uses default font of Windows for printing. Or perhaps a specific font which is not available on your system. I think only Pierre knows.
It sounds weird, but the fonts used by MS Word depend on the printer installed. Perhaps this problem is a bit similar, you might want to check your printer settings and printer installation. Does printing work in other applications? Which Windows platforms (95, 98, ...) do you use?xnview wrote:Yes i use default fonthelmut wrote: I have no clue why all the text in your prints are in Wingdings. I guess that XnView uses default font of Windows for printing. Or perhaps a specific font which is not available on your system. I think only Pierre knows.
ludul
FYI, I confirm it is printer specific.
I have the same problem as DICEASE when I try to print on an HP LaserJet 5100 (using WinXP), but it does not happen on the other printers I've tried.
I cannot find anything in the printer configuration that could explain this.
