I have used your program for the last few years on a daily basis and never had a problem. Suddenly, with the last update, 1.74 all I get is a script error. None of my pictures convert. I've tried uninstalling and reinstalling. Nothing seems to work
Can you help with this issue?
Program won't convert - errors (10)
Re: Program won't convert - errors (10)
on windows? same script?
karenbarr
Yes, Windows 10 - same script
karenbarr
Looks like it has been fixed.
Thank you!
Thank you!
Onewonderfulme
Hello. I'm using version 1.75, and I'm having the same issue. I cannot get anything to convert, specifically to PDF. Each time I get a "create error" and my file doesn't convert. It happened ever so often in the past, but now it's constant and I can't convert anything. I've uninstalled and reinstalled; still the same thing. How did you fix your issue? Thank so much in advance.
Edit: I'm using Windows 10 Pro, 32-bit operating system
could you post a screenshot of output tab?
