Filtering out certain image types
traycer
Post by traycer »
Hello all,
First, let me say that I love XnView and its cross-platform support! I recently upgraded to 1.80.3 from a much older version (might have been 1.74?). XnView now understands the Canon .CR2 raw files from my cameras, and will attempt to display them. I shoot in raw + JPEG mode, thus two files are created for every shot. Is it possible to filter out the raw files, and thus only browse/view JPEGs? The JPEGs are there for quick image browsing, but having to process the CR2s really slows things down.
I know it's a bit odd to ask an image viewer not to view an image :wink:, but I figured someone must have asked this before and I'm just not looking in the right place in the preferences to specify this. I see the "File Associations" section, but that only affects Windows Explorer's behaviour, not XnView's... is there something equivalent I can use to filter certain extensions?
Re: Filtering out certain image types
traycer wrote:Hello all,
I'll add a "ignore list" in the next release, see topic "Ignore list".
Drahken
Post by Drahken »
Some viewers have an option to only load associated filetypes while browsing.
What about moving the .CR2/raw files to a different directory?
traycer
Post by traycer »
Thanks, Pierre, looking forward to it!
traycer
Post by traycer »
Drahken,
That's my workaround for now (moving JPEG's to a separate directory), but that isn't always convenient, especially if I might end up with a directory that could have a mixture of CR2s, PSDs, PNGs, JPEGs, etc. and there is a dependency elsewhere in my workflow to have associated files in the same parent directory.
Post by Guest »
I take photos in JPEG and CR2 too in the same tame.
I have the same problem and I decided to turn back to the older version of XnView. It is not the solution for me to move CR2 files into other directory, because I used to go through the photos by JPEGs and when I don't like a photo, I mark JPEG version and CR2 version with CTRL key and then - delete both. Now XnView tries to show CR2 which takes a long time.
I'm not sure if I can download somewhere older versions of XnView...?
Anonymous wrote:I take photos in JPEG and CR2 too in the same tame.
Which version do you have, thumbnail for CR2 is the embedded thumbnail (if you have the option).
Drahken
Post by Drahken »
Go to tools->options->browser->thumbnail->use embedded thumbnail and see if that speeds things up.
http://download.xnview.com/old_versions/ has several older versions of xnview.
Peeotr
Post by Peeotr »
Thank you for response
Yes, I have this option, but checking it doesn't change the situation...
Peeotr wrote: Yes, I have this option, but checking it doesn't change the situation...
Could you sned me a sample, please?
