Rotate jpeg icon, doesn't start in folder, no delete
gothate
Post by gothate »
Here's just a couple things I noticed when playing with the latest version (1.80.3)
When opening a picture by doubleclicking it in explorer, then going from image view to the browser, the browser tree does not select the current folder *when the folder is the My Documents folder that has been remapped to a different folder*. Tools>Options>Browser>Startup Directory is set to "current" and Synchronize Browser selection with current is checked.
Several issues with the toolbar:
Tools>Options>Toolbar>Buttons Displayed
Unselecting all buttons in the Browser section will get rid of them until you close XnView. Then all the default(?) buttons will be back on restart.
* Also unselecting all toolbar icons will not collapse the toolbar.
Missing Rotate Counterclockwise option?
No delete toolbar icon!!!! C'mon! You're killing me here ;p
Wonderful program though. Left ACDSee years ago and never looked back!
Re: Rotate jpeg icon, does't start in folder, no delete
gothate wrote:When opening a picture by doubleclicking it in explorer, then going from image view to the browser, the browser tree does not select the current folder *when the folder is the My Documents folder that has been remapped to a different folder*. Tools>Options>Browser>Startup Directory is set to "current" and Synchronize Browser selection with current is checked.
And if you set it to "Last used"
Why do you want to hide all buttons, use View/Hide toolabr
You have it in jpeg lossless operation or in view mode
Delete is in mini toolbar (browser) or in file operations button
Post by Guest »
Same thing happens with "Last Used". Just has the file tree on the side with the Local Disk expanded but nothing else is. Actually ooh, found out what the problem was, it was set to be a hidden directory. Sorry!
Still don't see a rotate counterclockwise toolbar option in view mode? Not a big deal though with the lossless transform button.
Still hoping for a delete toolbar icon in image viewer. =>
Thanks for the super quick reply!
See---
:arrow: Guest
:) Hello !
• Please, see this reply about the same request… :|
:mrgreen: Kind regards,
Anonymous wrote:Still hoping for a delete toolbar icon in image viewer. =>
You have a button for File operation with delete!
Please continue discussion about the "Delete" button in topic Delete Button On Toolbar and see my comment there.
