Please add additional JPEG encoders like MozJPEG and Guetzli!
damian101
Post by damian101 »
It would be nice if you could add the option to change the encoder in JPEG settings.
Re: Please add additional JPEG encoders like MozJPEG and Guetzli!
damian101 wrote:It would be nice if you could add the option to change the encoder in JPEG settings.
Guetzli is already added
Added in XnView MP 0.89 viewer and batch convert, but not yet in XnConvert (1.76 current version) ?
Note: included as a separate 'JPEG Guetzli' entry, and a source file size limit as been identified (thread somewhere...)
Danny
Post by Danny »
+1 for MozJPEG
Guetzli is good at compression, but takes literally forever to encode with, neither supports progressive encoding nor color profiles. MozJPEG is about as good at compression and supports the other 2 things I mentioned while being a lot faster than Guetzli.
Couldn't this be implemented like a new image format? So in the dropdown it shows up next to normal JPEG encoding? I'm especially interested in support in XnConvert.
https://www.pixelz.com/blog/guetzli-mozjpeg-comparison/
Get the bugs fixed, THEN start adding features. It sucks, but someone has to do it.
Danny wrote:+1 for MozJPEG
What about an optimization feature (post-processing) with support of Guetzli, MozJPEG, JpegOptim, PNGOUT, PNGCRUSH, OptiPNG??
Danny
Post by Danny »
xnview wrote:What about an optimization feature (post-processing) with support of Guetzli, MozJPEG, JpegOptim, PNGOUT, PNGCRUSH, OptiPNG??
Not exactly sure what you're picturing, but yeah. Something along those lines. As long as there is no quality reduction through re-encoding of JPEGs involved.
damian101
Post by damian101 »
xnview wrote: Sat Mar 17, 2018 8:35 am
Just to avoid misconceptions:
Guetzli and MozJPEG are alternative JPEG encoders, any conversion will result in quality loss as JPEG has no lossless mode. JpegOptim can transcode a JPEG without loosing any image information (lossless compression).
PNGOUT, PNGCRUSH and OptiPNG can also do lossless PNG encoding/compression.
GUI for the Guetzli converter: https://www.guetzliconverter.net
GUI for the MozJPEG converter (online and limited only): https://mozjpeg.codelove.de
GUI for JPEGOptim: http://www.romeolight.com/products/jpegmicro/
GUI for best PNG compression: https://pnggauntlet.com
I am not shure what you mean by optimization feature? The only tools that make sense for post-processing are tools like JPEGOptim and of course all lossless encoders. I also think all of these encoders should be implemented in XnConvert and for every JPEG encoder, there should be the option to run it through JPEGOptim after encoding (MozJPEG does this by default).
pokuly
Post by pokuly »
It may be worth to add the latest Guetzli from Git. It works better here with files that had no good compression before maybe because of code optimizing and a new Butteraugli.
raysar
Post by raysar »
If mozjpeg is not added to xnview what GUI alternative have we to batch jpeg encoding? :)
(near all website use it but no windows software, for example photoshop jpeg encoder is a joke :/)
I don't know why all software use mozjeg as MAIN encoder.
Artifacts on black and white caracter in picture are horrible, mozjpeg do an incredible job.
Guetzli is not better than mozjpeg and is unusable because of time encoding.
happyman
Post by happyman »
I am also interested if there is any GUI converter with mozjpeg support?
Any plans to integrate mozjpeg in XnView in the nearest feature?
ashf
Post by ashf »
+1 for Mozjpeg encoder.
For png, I would like you to add pngquant.
https://pngquant.org/
user123
Post by user123 »
ashf wrote: Mon Dec 20, 2021 8:45 am +1 for Mozjpeg encoder.
I use Pingo PNG (https://css-ig.net/pingo) for compressing PNGs it seems to be the best one.
Also JPEG Guetzli seems to be abandoned, so MozJPEG would be a better option at this point.
https://github.com/google/guetzli (last release Mar 21, 2017)
sx090
Post by sx090 »
Oh, I just found that XNConvert built into XNView and the "standalone" version of XNConvert are not the same, is this normal?
From a SW-developes POV it looks more complex to maintain two versions, isn't it?
I was looking for Guetzli, and only found it in XNViews Converter, not in the Standalone XNConvert 1.100.1?
