NITF Format
NITF Format
I tried to open this NITF file http://164.214.2.51/ntb/baseline/softwa ... _3001a.ntf in XnView, but I get an error message stating that the format of the file could not be determined. Can anybody help me? Thanks in advance.
Re: NITF Format
I have downloaded your file and could view it in XnView without any problem (looks like a satellite image of an airport).Anonymous wrote:Hi,
For opening the NITF format, not plugins are needed. So there's perhaps an installation problem.
- Can you view and open the image in the XnView browser (start XnView and then browse to the folder with your image)?
- Which version of XnView do you use?
- Which Windows platform do you use (XP, 2000, ...)?
- Weird : here, your link displays ramdom characters on a new window, then the browser hangs...
IE 6.0 + Maxthon 1.5.0 Win XP-Pro
Olive
Surely only needed if a double-click in MS Explorer should open XnView and the appropriate image.Olive wrote:Rename i_3001a.ntf to i_3001a.nitf and if needed check nitf in options > associations
Not sure about this one. I thought this option only affects the number of formats listed in the "Open" and "Save" dialog.Olive wrote:Also i think you must check options > startup > use all formats available
From what I can see, XnView does not consider ".ntf" to be an extension for images in National Imagery Transmission Format, whereas ".nitf" is o.k.. In case the extension .ntf is often used for NITF images, Pierre could add this extension to the list of extensions.Olive wrote:Curiously, I could view and preview it with "use all formats" checked but no thumbnail until i renamed it to .nitf
If you want to keep the .ntf extension and see their thumbnails you have to uncheck the option "Tools > Options > Browser > File List > Recognize only by extension". This will slow down XnView a bit, but you shouldn't notice this much.
Ok, i'll add this extension tooOlive wrote:Rename i_3001a.ntf to i_3001a.nitf and if needed check nitf in options > associations
alove
Re: NITF Format
I encountered exactly the same problem. I can not open NITF files using XnViewer 1.91 on Windows XP. It says the format of the file could not be determined.
I found this old discuss on the same subject, but I don't know how this problem was resolved back then.
Alison
Alison
helmut wrote:I have downloaded your file and could view it in XnView without any problem (looks like a satellite image of an airport).Anonymous wrote:Hi,
alove
Re: NITF Format
To add to my previous note, XnViewer indeed can see some NITF files. In the following website
http://164.214.2.51/ntb/baseline/softwa ... n_2_1.html
XnViewer can only view i_3001a.ntf and i_3004g.ntf among all the NITF sample files in the above page. Does it mean all the other files are not valid NITF files or does it mean XnView has limited capability of viewing certain kind of NITF files??
Thanks,
Alison
Thanks,
Alison
alove wrote:I encountered exactly the same problem. I can not open NITF files using XnViewer 1.91 on Windows XP. It says the format of the file could not be determined.
Alison
Re: NITF Format
XnView has limited capability, but i'll check all these filesalove wrote:To add to my previous note, XnViewer indeed can see some NITF files. In the following website
DoubleDD
Re: NITF Format
Hi:
Can you add the file extesion for .nsf and .nsif ? They are for the NATO SECONDARY IMAGERY FORMAT (NSIF) format which is identical to the NITF format.
Thanks
DoubleDD
Thanks
DoubleDD
Re: NITF Format
okDoubleDD wrote: Can you add the file extesion for .nsf and .nsif ? They are for the NATO SECONDARY IMAGERY FORMAT (NSIF) format which is identical to the NITF format.
DoubleDD
Re: NITF Format
Pierre:
Can you post a new build with this fix in it ?
Thanks
Thanks
Re: NITF Format
the 1.98 beta is available...
DoubleDD
Re: NITF Format
Pierre:
I downloaded 1.9.8 beta 2 and it doesn't have NSIF as one of it's supported formats.
Can you add it as it is the same format as NITF ?
Thanks,
Bob
Thanks,
Bob
