multiple selection of favorites
Clavote
Post by Clavote »
Hi
I have 4 folders set up as favorites and I would like to select them All 4 for different re-categorizing works
unfortunately I couldn't find a way to select all 4 with the usual cntrl+A cntrl+click etc...
is this possible?
how would you work around?
merci
Clavote
Re: multiple selection of favorites
Clavote wrote: Sat Oct 27, 2018 2:17 pm I have 4 folders set up as favorites and I would like to select them All 4 for different re-categorizing works
Is this possible?
How would you work around?
In Batch convert, or do I misunderstand?
Clavote
Post by Clavote »
obviously I'm a newb so the names of things may be approximate
here I have one favorites selected. (OLD DCIM_A9)
how-to select all 4 to have all included pictures displayed in the central Pane
and then to be able to work on the complete body of pictures
thanks for your help
Clavote
sorry but currently it's not possible
