Picture It! .mix file support
kenj70
Post by kenj70 »
I found older posts on Xnview's handling of .mix files. However, I am running 64 bit Linux and a 32 bit .dll plug-in doesn't seem likely to work for me. I don't even know where the files for Xnview are stored! Please advise.
-=Ken=-
Re: Picture It! .mix file support
Welcome to the forum, Ken.
kenj70 wrote: Sat Jan 26, 2019 3:08 amI found older posts on Xnview's handling of .mix files. However, I am running 64 bit Linux and a 32 bit .dll plug-in doesn't seem likely to work for me.
XnView can only display the thumbnails embedded in PictureIt! files, becasue MIX is a closed proprietary format. Please refer to “Trying to convert a MIX to a jpg” for more information.
kenj70 wrote: Sat Jan 26, 2019 3:08 amI don't even know where the files for Xnview are stored! Please advise.
Tools → Settings… → Integration → Paths
