Wrong miniatures.
Thumbnails are wrong, preview shows right pictures.
Opening shows also the right picture.
Not all of them, only the replaced pictures with the same filename.
Refresh does not change thumbnails.
Greetings
pvpp
previews are right, thumbnails are wrong
pvpp
Re: previews are right, thumbnails are wrong
if you copy this file, the thumbnail is correct?
pvpp
Yes, when I copy the file to another place, then thumbnail is correct.
and do you have a way to reproduce this behavior?
pvpp
Same folder content at the same time, view in XnView, GraphicConverter and Finder.
The pictures were cropped by GraphicConverter (to leave it at 48 Bit).
There are few pictures with special behavior
Copy or move them to another folder, then are all miniatures OK.
Just renaming folder, then are all miniatures OK.
Renaming back to the original folder name, miniatures are wrong.
even if you use View>rebuilt thumlbnails?
Phred
Without a local Help file, this is hard to track.
There's 'EXIF thumbnail - Rebuild' under Tools, Metadata - and there's View, Rebuild thumbnails (in Browser mode).
I wonder if there's a difference.
Regards, PhredE
'Tools>Metadata>EXIF thumbnail - Rebuilt' rebuil the embedded thumbnailPhred wrote: Wed Jun 26, 2019 9:21 am There's 'EXIF thumbnail - Rebuild' under Tools, Metadata - and there's View, Rebuild thumbnails (in Browser mode).
