Hi
I like Xnview MP a lot.
The only thing that i am missing: I dont have thumbnails or a preview for SVG files.
There are a lot of Post's around with the Subject SVG. I tried to put the CS_SVG.dll into the plugin folder. Without success.
I can't see even the files (with symbols) in a specific folder full with SVG Files.
I am using the portable Version.
Thank you Christoph
SVG Support missing
Re: SVG Support missing
what do you have in settings>Filelist>Custom filter?
galbur
Hi Pierre
Perfect. That was the point ..
Thank you
Best Regards
Christoph
Thank you
Best Regards
Christoph
