Create a CD
RoseW
Create a CD
Post by RoseW »
Is it possible to have an alternate cd burn software in the drop down menu (With Nero Burning Rom) I uninstalled Nero and use CDburnerXp. Is there a way to edit the menu command to relate to CDburnerXp?
Rose Weir
klumy
Post by klumy »
XNView Deluxe can do this
http://www.xnview.fr/site_uk/
XNView 1.91.5
Windows XP SP3
Re: Create a CD
Post by Guest »
RoseW wrote:Is it possible to have an alternate cd burn software in the drop down menu (With Nero Burning Rom) I uninstalled Nero and use CDburnerXp. Is there a way to edit the menu command to relate to CDburnerXp?
Rose Weir
The drop down menu in XnView has the choice to Create a CD. It appears that it is a shell exe to open the software by Ahead-Nero cd burn.
To have a choice of another cd burning software one must purchase the pro level XnView?
When the task is to just burn a copy of the image folder to CD it seems a little strange that this subcontext menu could not be connected with an Open With command.
RoseW
A deal ?
:) Hello Rose !
¤ This astonished me the first time I saw that command, and continues to do still… :?
- Maybe Pierre has a sponsoring deal with Nero ? Image (I don't think, really…)
¤ You might post a request in the appropriate section, I would support it ;)
{ Aside : BTW, why not sign up as a member here? This brings much more capabilities… }
:mrgreen: Kind regards,
marsh
Post by marsh »
There are also windows ports of linux "cdrecord" (command line, no ASPI layer needed on win2k). Since there are other versions of Xnview, perhaps this might interest someone.
Enhanced issue…
:arrow: Pierre
:) Hello Pierre,
¤ BTW, the Rose's remark and suggestion for an “Open With…” command pose another issue in the following case :
- In Total Commander, we have an excellent (free of charge) CD-burning plugin based on the FoxBurner® programme so-called TCBurner (allowed, the author is the developer @ FoxBurner's…).
- This plugin works as a "File System" plugin, and this is a bit special.
- The point is how that plugin could be used through TC, since it is not a classic EXE to launch ? Many TC-users have only this plugin for the CD-burning and are happy with it…
- Maybe Ch. Ghisler could give you some info in order to get that works from XnView.
- We have a (good) French Manual for that plugin, you could read it hoping this could help… 8)
RoseW
Re: A deal ?
Post by RoseW »
Clo[/quote]
Okay, I have now signed up as a member :D
Is the appropriate section the REQUESTS group?
Rose
Glad...
:) Hello Rose, bonjour !
¤ Congratulations ! Welcome aboard as a Member !
…Is the appropriate section the REQUESTS group?
- Absolutely ! The “Requests & Suggestions” section is the right place to ask for an improvement, as well a change of an existing one, as for a quite new one…
…Is there a way to edit the menu command to relate to CDburnerXp?
:( The question that angers… To edit menus, they must be built as text-files… We hope that'll be changed, already a start is coming for the EXIF data (for translations)
{ Aside again : please, give a glance here ;) }
