Batch Enhance Colours - Saturation
mrwul
Post by mrwul »
When I go into Image > Adjust > Enhance colors there is a Saturation, being just 1 slider.
In Batch Convert the Add Action > Map > Saturation is different (Red/Green/Blue/Cyan/Magenta/Yellow).
Should I all set the same, e.g. -10 ?
I don't know how to handle that.
Also what should select for 'Hue' from the Add action > Map list?
Thanks.
Re: Batch Enhance Colours - Saturation
if you want to use the same, choose 'HLS'
mrwul
Post by mrwul »
Sorry for the late reply.
Many thanks indeed!
