[0.94.1]The extension name of the resulting image is incorrect when convert a png image to jpg image
FWhite
When I converted a png image to a jpg image, the extension name of the resulting image remained ".png", but not ".jpg".
Re: [0.94.1]The extension name will not change to ".jpg" when convert a png image to jpg image
by using batch convert?
FWhite
FWhite
Re: [0.94.1]The extension name of the resulting image is incorrect when convert a png image to jpg image
Software: XnView MP 0.94.1 Zip Win 64-bit
OS: Windows 10 LTSC - 64-bit
1. Select a png image file.
2. Click "Tools - Batch convert".
3. Choose the "Output" subfield. Set "When output files already exist" as "Skip" and check “Use CPU Cores”. Choose the "format" as "JPG - JPEG / JFIF".
4. All other setings remain default.
5. click "Convert". Please notice the extension name of the resulting image file. It's ".png", but not ".jpg".
It is interesting that the operation history may affect the result. I started XnViewMP, and did the png-to-jpg conversion immediately (keep the settings as described above); the bug recurred. Then I did some other conversion operations. Did the png-to-jpg conversion again, sometimes the bug recurred again, but sometimes the bug disappeared. I'm sorry that I didn't find the law.
what do you have in 'Filename'? 'Preserve extension' is enabled?
FWhite
The filename is "{Filename}_result", and the output folder is "Source folder".
FWhite
The screenshots of the settings and status are shown below.
Right
please disable 'preserve extension'
FWhite
Thanks for your time and solution.
