I run XnView on Ubuntu 18.04 LTS and understand most people use Windows
I need to disable XnView's ability store clipboard data as I have reason to believe it causes a library conflict that causes gimp to crash. Does anyone know if this is possible?
Disable import from clipboard
BK201
Re: Disable import from clipboard
what do you means by 'store clipboard data'??contrast wrote: Sat Feb 15, 2020 10:00 pm I need to disable XnView's ability store clipboard data as I have reason to believe it causes a library conflict that causes gimp to crash. Does anyone know if this is possible?
