FIles.xmp and Categories.txt -
unqltango
Post by unqltango »
If for some reason I lose my XnView.db, can I recreate my data from the exported categories list and the files.xml? Does files.xml contain all the keywording work I have done until the export?
I'm asking this because the files.xml is much smaller than the XnView.db (about 8MB .xml vs 90MB .db). The xml contains however 115K lines, so that is a lot of keyworded media.
Thanks,
Tango
Re: FIles.xmp and Categories.txt -
the categories are stored in .xmp/embedded metadata?
unqltango
Post by unqltango »
xnview wrote: Tue Feb 25, 2020 10:58 am the categories are stored in .xmp/embedded metadata?
Sorry, I made a typo in the subject. I wanted to write files.xmL. The file what you get by using the option to Export File's Categories.
If possible, the categories are stored in metadata too (pictures), but I keyworded other types of media as well, movies, .swf, folders, etc.
you can save the xnview.db, or export with 'Export File's Categories' for the .xml
unqltango
Post by unqltango »
Thank you, so the files.xml contains ALL keyworded media as well. That is very useful.
BR,
Tango
unqltango wrote: Wed Feb 26, 2020 8:59 am Thank you, so the files.xml contains ALL keyworded media as well. That is very useful.
ALL from .db
