Hi..
I'm sorry ... I posted this message on the XnView Classic board by mistake. I don't intend to spam.
Please ignore the previous post. This is an issue with XnViewMP.
[BUG]
The XnViewMP allows to add custom commands (_cmd_) to the toolbar, which is pretty useful, but when the applications are located on OneDrive (and most likely any other cloud service) and the sync tool is running, the command icons disappear and the toolbar only shows their caption. It still works, but breaks the design and takes more space from the screen, so part of the toolbar ends up out of the screen workspace. This is most likely related to the icon overlay used by cloud services. Perhaps XnView should have a cache for the command icons. XnViewMP's own icons of course are not affected although the program it's also located on the cloud folder.
[FEATURE]
I would also like to propose the feature to allow to change keyboard shortcuts for custom commands (_cmd_) and "OPEN WITH" commands. The first ones currently don't have shortcuts assigned, and the latter ones have the static series from alt+1 to alt+9. I think this is an important feature to speed up workflow that should be taken in consideration.
Thank you for such an amazing piece of software..
Toolbar commands lose icon if OneDrive is running
mdnava
Re: Toolbar commands lose icon if OneDrive is running
The QT Api try to load the icon from EXE, so in your case it seems that the file can't be readed
mdnava
The icon problem happened with any program running from the OneDrive folder that was added to the XnViewMP toolbar. And it happened when OneDrive is running. Otherwise the icons showed properly when OneDrive was paused.xnview wrote: Sat Mar 21, 2020 2:46 pm The QT Api try to load the icon from EXE, so in your case it seems that the file can't be readed
However, I just updated to v0.96 and icons now show as they're supposed to.
But now image information on fullscreen replaces regular spaces with html no-break space codes ( ).. it's a strange behaviour..
Maintenant, les informations sur les images en plein écran remplacent les espaces simples par des html codes: .
C'est un comportement étrange, je pense.. Mais ce n'est pas lié au problème avec OneDrive. J'ai ajouté une pièce jointe.
